jkpete
- Novice
- Liked: 1 time
- Full Name: Jeff
- Contact:
Re: Installation fails (SQLLocalDB)
Haven't yet. will be trying tonight.
Dima P.
- Product Manager
- Liked: 1890 times
- Full Name: Dmitry Popov
- Contact:
Jeff,
Thanks. Awaiting for your reply.
mbaumli
- Lurker
- Liked: never
- Full Name: Michael Baumli
- Contact:
Install Error"Exception has been thrown by the target of an"
I am getting an installation error on clicking "An error has occurred: Exception has been thrown by the target of an invocation.
There is another more detailed screen which gives additional information, but the error is rather lengthy
But the log shows this:
Windows Installer installed the product. Product Name: Veeam Endpoint Backup BETA. Product Version: 8.0.0.1822. Product Language: 1033. Manufacturer: Veeam Software AG. Installation success or error status: 0.
I would log a support case, but this is a "free" beta product and assumed that there was no support for this product. If this is wrong, please let me know.
Dima P.
- Product Manager
- Liked: 1890 times
- Contact:
Hello Michael,
You are welcome to submit a support case. I am tracking the similar issues in this thread, kindly, please take a look at this post. In addition, to the described procedure please check that SYSTEM account has full access permissions to systemprofile folder (C:\Windows\System32\config\systemprofile).
massimiliano.rizzi
- Service Provider
- Liked: 34 times
- Full Name: Massimiliano Rizzi
- Contact:
Hello Dmitry,
I recently tried to install Veeam Endpoint Backup on a HP MicroServer ProLiant Gen8 running Windows Server 2012 Essentials and I think I am having a similar problem with Microsoft SQL Server 2012 Express LocalDB installation/configuration.
Since the problem is on a server, may I kindly ask the support team to review the logs before I go ahead and attempt to perform the instructions you have prepared for anyone who faced installation issues.
I have collected and shared all relevant logs and I am sending you the link via PM.
Thank you in advance for your support.
Massimiliano
Massimiliano
Dima P.
- Product Manager
- Liked: 1890 times
- Contact:
Massimiliano,
Thanks for providing the logs. Will investigate and follow up shortly.
massimiliano.rizzi
- Service Provider
- Liked: 34 times
- Contact:
Hello Dmitry,d.popov wrote:Massimiliano,
thank you for your follow-up.
Looking forward to hearing from you.
Thank you again for your support.
Massimiliano
Dima P.
- Product Manager
- Liked: 1890 times
- Contact:
Massimiliano,
Can I ask you to do the following:
- Download and install Microsoft® SQL Server® 2008 Management Studio Express
- Check HKEY_LOCAL_MACHINE\SOFTWARE\Veeam\Veeam Endpoint Backup for the following values: SqlInstancePipeName and SqlLogin / SqlPassword
- Try to open Endpoint database via Management Studio with SqlInstancePipeName as a server name, SqlLogin / SqlPassword as login and password using SQL authentication.
- Check Under Security > Logins what accounts are listed
Send me a screenshot of exising accounts via this post or PM. Thank you.
massimiliano.rizzi
- Service Provider
- Liked: 34 times
- Contact:
Hi Dmitry,
thank you for your reply.
I will perform the steps above and let you known the result as soon as possible.
Regards,
Massimiliano
Regards,
Massimiliano
massimiliano.rizzi
- Service Provider
- Liked: 34 times
- Contact:
Dmitry,
sorry for the delay.
Please find below all relevant screenshots:
Management Studio seems not to be able to connect to LocalDB from within this HP MicroServer ProLiant Gen8 running Windows Server 2012 Essentials. The same procedure works from within another server.
Thanks and Regards,
Massimiliano
Thanks and Regards,
Massimiliano
Dima P.
- Product Manager
- Liked: 1890 times
- Contact:
Massimiliano,
Anything from TrendMicro installed on your machine? Could you shut it down and then reinstall the product – its #1 troubleshooting step from the guide above
massimiliano.rizzi
- Service Provider
- Liked: 34 times
- Contact:
Hi Dmitry,
thank you for reply.
I confirm Trend Micro Worry-Free Business Security Services is installed on this machine. I have to say that I have successfully installed Veeam Endpoint Backup on a number of Microsoft Windows 7 SP1 64-bit endpoints and they are all running Trend Micro Worry-Free Business Security Services.
As part of #1 troubleshooting step from the guide above, I have just unloaded the Worry-Free Business Security Agent using the “Security Agent Uninstall Tool” (a tool Trend Micro provides to manually unload and/or uninstall their Agent).
I have not yet tried to reinstall Veeam Endpoint Backup because Management Studio is not able to connect to the LocalDB instance even after unloading the Worry-Free Business Security Agent, so I doubt Veeam Endpoint Backup will install successfully if the product cannot connect to the LocalDB instance.
The LocalDB instance itself seems good:
Unfortunately I am not a SQL guy and I am having a hard time in the attempt to detect what's wrong with the unsuccessful connection to the LocalDB instance.
Thanks and Regards,
Massimiliano
Thanks and Regards,
Massimiliano
massimiliano.rizzi
- Service Provider
- Liked: 34 times
- Contact:
Dmitry,
as part of trying to connect SSMS 2008 to the LocalDB instance using named pipes, I managed to get the address of the Veeam Endpoint Backup LocalDB instance by running the following commands:
1. "C:\Program Files\Microsoft SQL Server\110\Tools\Binn\SqlLocalDB.exe" start VeeamEndPoint
2. "C:\Program Files\Microsoft SQL Server\110\Tools\Binn\SqlLocalDB.exe" info VeeamEndPoint
Please find below the results:
C:\Windows\system32>"C:\Program Files\Microsoft SQL Server\110\Tools\Binn\SqlLocalDB.exe" info VeeamEndPoint
Version: 11.0.2100.60
Shared name:
Owner: NT AUTHORITY\SYSTEM
Auto-create: No
State: Running
Last start time: 18/02/2015 14.15.03
Instance pipe name: np:\\.\pipe\LOCALDB#5055F163\tsql\query
The above command returns “np:\\.\pipe\LOCALDB#5055F163\tsql\query” as the instance pipe name, while HKEY_LOCAL_MACHINE\SOFTWARE\Veeam\Veeam Endpoint Backup returns “np:\\.\pipe\LOCALDB#8C5F36B7\tsql\query”.
When I try to open the Endpoint database via Management Studio using the instance pipe name returned in the "SqlLocalDB.exe info VeeamEndPoint" command above I do get a “Login failed” error:
Based on the results, Case B of the troubleshooting steps from the guide above (delete and re create the instance) should be the way to go.
Massimiliano
EDIT: I just realized the portion of the Instance pipe name after LOCALDB# will change each time the instance of LocalDB is started.
Shared name:
Auto-create: No
State: Running
Massimiliano
Dima P.
- Product Manager
- Liked: 1890 times
- Contact:
Massimiliano,
My bad, I should have mentioned that every time Endpoint service is restated SQL access credentials and pipe name are changed, but Its reflected in the registry. I’ve noticed that TrendMicro could affect the Endpoint setup and even corrupt the Endpoint database instance but it happens very sporadically.I just realized the portion of the Instance pipe name after LOCALDB# will change each time the instance of LocalDB is started.
massimiliano.rizzi
- Service Provider
- Liked: 34 times
- Contact:
Hello Dmitry,
sorry for the delay, I was out of the office for the last couple of days for a training.
I received your PM and performed the following step-by-step instructions:
- Uninstalled Endpoint
- Rebooted the machine
- Disabled Trend Micro Worry-Free Business Security Services
- Added to HKEY_LOCAL_MACHINE\SOFTWARE\Veeam\Veeam Endpoint Backup key Name = Recreatedatabase Type = DWORD Value = 1 via regedit.exe
- Started Endpoint setup again
I noticed that the pipe name is changed in the registry, however the installation program still fails to start the service ‘Veeam Endpoint Backup service’:
Massimiliano
Massimiliano
Dima P.
- Product Manager
- Liked: 1890 times
- Contact:
Massimiliano,
Thanks for the update. Please send me the fresh portion of troubleshooting logs via PM.
massimiliano.rizzi
- Service Provider
- Liked: 34 times
- Contact:
PM sent.
Thanks and Regards,
Massimiliano
massimiliano.rizzi
- Service Provider
- Liked: 34 times
- Contact:
Dima P.
- Product Manager
- Liked: 1890 times
- Contact:
Massimiliano,
Thanks - forwarded your logs to QA team. By the way, any chance that the affected machine is in domain with some password GPO (or maybe local policy)?
massimiliano.rizzi
- Service Provider
- Liked: 34 times
- Contact:
Indeed, the affected machine I am trying to install Veeam Endpoint Backup on is running Windows Server 2012 Essentials. It is the domain controller at the root of the forest and domain.
The affected machine is acting as a file server (we have not installed other applications) and all GPOs come out of the box with Windows Server 2012 Essentials without any customizations/additional GPOs.
Is there any particular Group Policy setting I should also look into ?
Thanks and Regards,
Massimiliano
Dima P.
- Product Manager
- Liked: 1890 times
- Contact:
Hi Massimiliano,
Thanks for the update! In several cases we have confirmed the generated SQL password to be the root of the issue (as the password does not meet some default GPO requirements). It will be corrected in GA, meanwhile please check the hotfix and solution I've sent you and let me know it helps. Thank you.
massimiliano.rizzi
- Service Provider
- Liked: 34 times
- Contact:
Hello Dmitry,d.popov wrote:Hi Massimiliano,
thank you for your quick reply.
I am attempting to reply via PM to the message containing the hotfix and solution you sent me via PM as well, however my replies get stacked up in the Outbox folder of my User Control Panel. I don’t know whether you’re receiving them.
The х64 bit folder containing the .dll pack also contains a subfolder named “х64” (there also is a subfolder named “х86”). The “х64” subfolder contains two files: “NtfsLib.dll” and “VeeamAgent.exe”. Do I have to grab and copy them as well ?
Thanks and Regards,
Massimiliano
Dima P.
- Product Manager
- Liked: 1890 times
- Contact:
Massimiliano,
Yes, all the files should be replaced.
massimiliano.rizzi
- Service Provider
- Liked: 34 times
- Contact:
I followed your instructions containing the hotfix and solution you sent me via PM and I confirm everything is ok
Thank you again for your kind support.
Massimiliano
Dima P.
- Product Manager
- Liked: 1890 times
- Contact:
Massimiliano,
Awesome! Thank you for your time!
stoal76
- Novice
- Liked: never
- Full Name: Shane
- Contact:
Can I please have a copy of this hotfix as I am getting the following error when installing Endpoint RC on a Windows 2011 essentials server
Log Name: Application
Source: VeeamEndpointBackupSvc
Date: 10/03/2015 1:01:32 p.m.
Event ID: 0
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer:
Description:
Service cannot be started. Veeam.Backup.DBCreator.DatabaseException: Unable to connect to SQL Server np:\\.\pipe\LOCALDB#8E61A0D8\tsql\query. Login failed for user 'VeeamLogin'.
at Veeam.Backup.DBCreator.DatabaseConnector.Connect(DatabaseConnectorOptions options)
at Veeam.Backup.DBCreator.DatabaseIsCompatibleTester`1.Test(Exception& error)
at Veeam.Backup.DBCreator.DatabaseIsCompatibleTester`1.Test()
at Veeam.EndPoint.CEndPointServiceImpl.PrepareSqlInstance(DatabaseFile databaseFile)
at Veeam.EndPoint.CEndPointServiceImpl..ctor(CVbOptions options, CTerminationMediator terminator, CExternalEventsWatcher externalEventsWatcher)
at Veeam.EndPoint.EndPointService.OnStart(String[] args)
at System.ServiceProcess.ServiceBase.ServiceQueuedMainCallback(Object state)
Event ID: 0
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer:
Description:
Vitaliy S.
- VP, Product Management
- Liked: 2997 times
- Full Name: Vitaliy Safarov
- Contact:
Hi Shane, keep in mind that you can get it via our support team (cp.veeam.com) as well. Thanks!
Dima P.
- Product Manager
- Liked: 1890 times
- Contact:
Hi Shane,
Just to clarify, you installed the latest RC built (released last Friday) ? Is it possible to share the screenshot of the error you received? Thank you in advance.
stoal76
- Novice
- Liked: never
- Full Name: Shane
- Contact:
The Veeam RC version that I installed is 1.0.0.1921
Here is a screenshot of the installation error
https://onedrive.live.com/?cid=DEC48D57 ... 128696&v=3
If I run the commands below it looks like the SQL Local DB is not being created in the installation process.
The specified LocalDB instance does not exist.
Printing of LocalDB instance "VeeamEndPoint" information failed because of the following error:
LocalDB instance "VeeamEndPoint" doesn't exist!
Dima P.
- Product Manager
- Liked: 1890 times
- Contact:
Shane,
Thank you! For further troubleshooting could you please collect the following information and share via any available cloud storage with me (send me a download link via PM):
- The full setup logs from C:\ProgramData\Veeam
- Windows Event logs from windows event viewer (Custom View > Administrative events)
- LocalDB error log from %systemroot%\system32\config\systemprofile\AppData\Local\Microsoft\Microsoft SQL Server Local DB\Instances\VeeamEndPoint\ (it should look like error.log, error1.log, error2.log etc)
Users browsing this forum: Google [Bot] and 19 guests
